Configures the LLDP port to advertise or not advertise Power over Ethernet (PoE) capabilities to its neighbors.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| advertise | Specifies to send the information to neighbors. |
| no-advertise | Specifies not to send the information to neighbors. |
| with-classification | Specifies to use LLDP for Data
                                Link Layer Classification. This option is available only on PoE+ ports. |
No advertise.
When configured, the system includes this TLV. We recommend enabling this TLV only on PoE-capable ports.
Support PoE or not
Power sourcing equipment (PSE)
Powered device (PD)
Signal
Spare
Power status
Support pairs control or not
Class0
Class1
Class2
Class2
Class3
Class4
Data link layer classification allows fine-grained dynamic re-allocation of power based on changing needs. This feature is enabled by enabling LLDP (transmit and receive) and configuring transmission of the power-via-MDI TLV. The ExtremeXOS software sends an LLDPDU containing a power-via-MDI TLV within 10 seconds of DLL classification being enabled. A PD may request a new power value using an LLDPDU. The allocated power might be changed if a request is received and approved after a power review. The software responds with an allocated power value within 10 seconds of receipt of an LLDPDU with a different requested power from a PD. Power allocation can be controlled to a granularity of 0.1 watts. When DLL classification is enabled, it takes precedence over physical classification.
For more information on advertising power support, see the configure lldp ports vendor-specific med power-via-mdi command.
The following command configures all ports to advertise power capabilities to neighbors:
configure lldp ports all advertise vendor-specific dot3 power-via-mdi
